- Dec 20, 2021
- 1,066
It's a little bit more complex than just metal is reflective. Different metals are more reflective to different colors of light than others. There are different wavelengths of lasers available. Some 'laser engravers' are blue (~450nm), Co2 (~1064um), with many industrial being Nd:YAG (~1064nm.) Some of the choice of wavelength comes from cost of the laser source. 450nm blue's (Laser Diodes) are pretty simple and cheap to make. CO2 are cheap-ish but a bit more complex. Nd:YAG is a pumped laser crystal, and a bit more complex.
Note, we have 1064nm welding lasers at work. We use them quite often to weld all sorts of unusual things together. Butt welding .008" diameter wires, welding plugs into exotic metals, etc. Think of a microscope with cross hairs and 2mm to 0.5mm spot size. I've even used them to drill a .5mm hole through an 3/16 hardened steel.
I almost bought a Nd:YAG laser head for engraving. This would have been a diode pumped solid state laser. The average power was ~10W, but since these are pulsed peak pulses are actually closer to 60KW! This laser head would engrave, and even cut 1mm copper and steel, cut glass, or just about anything without coating it. Part of the deciding factor against the purchase (other than cost) was the safety aspect. Wasn't completely sure that I wanted something like that in the shop. Very certain a suitable enclosure could be built, that the enclosure/process was part of the factor against it.
If anyone buys a laser, please brush up on safety with these. Anything that can cut or mark metal is going to be Class 4. One false move could mean the loss of an eye before you even realize it happened. These things are no joke, and eyes are important!
