I too had the same problem with the Z axis bleeding down on my one-shot lube system. Instead of using check valves used ball valves. I split the feed line into two circuits with a tee. One side of the tee feeds the X and Y axis and the other side feeds the Z axis. Each of the feed lines has a ball valve so I can close off one of the feed lines and pressurize the other. In essence the ball valves are manual check valves. I no longer have a problem with the Z axis bleeding down. Just another way to solve the problem.
Tom S
Tom S
