- Jan 25, 2015
- 2,558
I recently bought a couple jacobs chucks in various states of neglect. One was a jacobs 16N super chuck.
I took it apart and cleaned off a lot of the abuse with a light skim off the external surfaces.
The jaws showed some wear, but seemed to clean up nicely with a little stoning.
I’ve had it apart a couple times now, chasing the runout.
I don’t even want to talk about what it was when I got it, seeing it was stupid high in the 0.1” to 0.2“ range.
I indicated the JT3 in the drill press and got a tir about 0.0005”. Nothing bad there!
Then I mounted the bare body in the lathe and zero’d it out on the sleeve ring on the body. Then moved to the JT3 taper in the chuck body. Indicated about 0.004”. Not great, but not horrible. Oddly enough, it showed the same .004” out on the end of the taper.
So I went back and assembled the chuck, taking special care to make sure the split right and gear teeth mated without moving the jaws in any direction.
Then, I chucked up a rod from a shock absorber. The rod is hardened, ground and very tight tolerances. I indicated it on v-blocks and got zero runout.
Next, I indicated it and this was the resukts:
Thats right about 0.0016“. pretty good, but its right up against the jaws.
at the bottom of the rod:
Thats about 0.010”.
So yeah, pretty sure the jaws are worn.
Kits are pretty hard to find it seems and the only ones I’ve run across are asking very dear prices.
I might see about trying to true the jaws up a bit more with some of the grinding methods I’ve seen about the ‘net.
It’s “only” on a drill press, but I’d like to get it running as true as I can. Bad enough some drill bits “wobble around” on thier own, last thing I want to do is introduce 0.010 before the drill is even chucked up.
Any input on how I should proceed?
Cheers
Thats about 0.010”.
Cheers
