- May 7, 2023
- 1,935
As long as it's flat and doesn't effect your work piece. To me, it just looks like cosmetic damage that doesn't reflect on the actual workpiece.
Pic I took but didn’t post. I had a job in the mill that I had to finish so I could get some feeler gauges under it to see the extent of the damage.
The feeler gauge is just to the right of the based in corner. Adjacent side is about .005-.006
Flipped it upside down and milled that spot and it’s good enough for right now. I’ll probably throw it up on the surface grinder and clean everything up at some point.
You can see a second high spot just to the right of the endmill. I went about .002 under the surface in this spot and then stoned it.
