- Aug 6, 2015
- 4,291
Thank you for the reminder. Those were attached to the vise. I just forgot to install them back. You can see them in the photos from when I got the machine. Here, take a look:Those screw holes on the side of your chuck are for mounting a backstop rail onto the chuck. Everyone Ive ever seen is located on the column side of the grinder hence “backstop”. There is usually a side stop also which is located on the left side of chuck which is used to stop parts from getting flung off the chuck.
Both of the rails/stops should be ground in place on the grinder so they are in perfect alignment with both axis.
I will install them back in a little bit.
