Using boring bar in boring head
Hi again. I was very bussy with the project, and , as you said, the problem was a too small hole. Fixed. Thank you again
Now, I still want to use a boring bar where I can change the insert, but as you said, the boring bar I was using is meant to be used in a lathe. But, if the hole is big enough, Can I use that boring bar in the boring head? I have check the boring bars that ChazzC suggested, butI live in Spain and theese tools here are hard to find or expensive, so if I can go with the lathe boring bar, i would prefer it.
Check out this place, RC-Machines out of Luxemburg.
