Hi, I did that dance with the centrifugal switch, what I did was remove the shaft mounted part by hitting it with a chisel in the center. that expanded it and it slid off. I purchased a new one (press on) and installed the new one I then pinned it in place. it was impossible for me to get the shaft mounted part to move without destroying it.
the plastic fan was removed with a crowbar on each side.
I guarantee that you will be back in the motor working on that stuff, what I believe is when the motor starts it actually spins the fly weights and that causes it to move.
I realized the problem that I had with the capacitor dying was because of overheating. I was doing small parts and frequently edge finding, that overheated the start capacitor.
I have mine running again, but for how long. I am in the process of replacing the motor with a 3 phase one and a drive. I need the mill to make an adaptor plate for the new one.
I noticed that PM is selling a 940V that has a 3-phase motor and a drive, if they had that when I purchased mine, I would have chosen that one.
good luck Rich
good luck Rich
