Preventing two more broken taps
I tap #4-40 threads tap drilled #43 in 1018 with a reversing tapping head at 800 - 1000 rpm all day using some old sulphurized cutting oil I've had for years and I've power tapped #4-40s with a 3 phase Bridgeport, you have to be careful but it can be done. I don't know about the Irwin taps as I've not seen them but it sounds like a tap you would buy at the local hardware and just as a rule, run away from that isle. Go to a local industrial supplier, KBC, Traverse, Shars, etc., even the cheap Chinese tools they sell are better. The steel is likely better, the heat treating is better and the threads are ground better, you will save money in the end. The other suggestion I'd make is that if it's a through hole, use a spiral point tap, they are MUCH stronger and you don't have to back them up every turn to break the chips. Did I mention that they are MUCH stronger. If the hole is not a through hole, drill it about a third of the tapped length deeper so there is somewhere for the chips to go, these taps push the chips ahead of the tap. Finally, if the thread is engaged more than 3 - 4 diameters, in this case .3 - .4 inches, you will break almost any bolt before you strip a 50% thread so you can drill oversize and if you're using a machine screw or a grade 5, all you need is 2 - 2 1/2 diameters. This application shouldn't require it but if you're tapping stainless, some of the higher strength steels or titanium, go oversize. Just as an additional point for tapping, if your tapping steels in general, use a black oxided tap and the bright uncouted taps for aluminum, the black oxide coating is supposed to retain an oil film to prvent buildup on the face of the cutting edge and the bright finish is smoother ata microscopic level preventing the aluminum from sticking
