- Aug 22, 2012
- 4,291
Its been a long time since I got any shed time but managed a bit in the last week.
Made the angle plate from 8mm plate and welded it together. Managed to control the welding distortion and kept it square.
I was rather pleased with the 8x1mm thread, it came out pretty good, not perfect but more than good enough.
The end of the feed screw was hand filed square (sort of) likewise the hole in the handle. It only has two ends because I couldnt turn a four handled one.
The aluminium casting is an old one from my gingery lathe (never finished)
As I will be cutting a 40 tooth gear I needed a means of indexing it.
This site will print an index wheel for any divisions you want.
http://www.cgtk.co.uk/metalwork/divider
I used spray adhesive to stick the divider to a thin sheet of steel and sealed it with lacquer.
The angles are bolted to the slide with 5mm c/sunk screws, 4 in each angle.
The shaft is 8x1mm, and is the best thread I've cut so far.
The gap between the top of the handle and the index wheel is actually larger than it looks in the photo.
Still have to make the pointer then its onto the lathe and have a go at cutting the gear.
No idea when that will be but I hope its soon. I was suffering from shed withdrawal symptoms.
