It seems that my quest for a reverse tumbler and my stinginess preventing me from purchasing the requisite 40T gear is leading me into deeper territory.
I decided to make a small vertical slide to help in cutting the gear blank.
I had a small topslide casting already made for the Gingery lathe so thought I may as well use that as a starting point.
Everything else must come from the scrap bin (remember I'm stingy)
I cant produce engineering drawings and cant really read them either so I tend to work out my projects in an old 3d modeling/animation program to get it clear in my head and came up with this. It does mean I can check out clearances and fits before I cut anything as I can read the measurements of the model.
The 50mmx6mm angle is probably too wimpy so I think it will need a couple of full height triangular braces
I found a length of 42x22mm steel bar from I think a washing machine packing spacer so cut a length off with an angle grinder.
The 42mm needed reducing to 35mm so I chucked it in the 4 jaw, roughly centered it, reduced the speed to 350rpm and proceeded to remove the 7mm using a 1/2" round nose bit I had been given. I thought this would be a better proposition as this was a very interrupted cut and I was unsure what would happen to a 6mm cutter.
This was a very rough cut and I couldnt get it set low enough to the centre line so it left a large cone (too large to be called a pip).
I then ground a 6mm HSS cutter to a radiused end and stoned it sharp to use as a finishing cut.
I was astounded at the finish it produced so then decided to remove all the fire scale on all 6 sides to give a nice looking rectangular bar of steel. The 12mm square of plate its sitting on will be the base.
I learnt something very valuable in this exercise,
1, interrupted cuts produce very small but very very hot chips that raise tiny blisters. Ouch!
2, Using the rear of the jaws in the 4 jaw as a reference surface for the facing cuts is not a good idea, one of them may be slightly thicker than the others, the block of steel ended up 0.2mm difference from end to end and the end faces are not quite square. I'm hoping I can shim this square in assembly. Or maybe bite the bullet and file it square.
Next I drilled and filed a slot through the middle for the slide screw,As you can see I stopped before it was totally flat. I plead the weather, its 92'F and 80% humidity so I stopped.
I decided to use a length of 75x6mm cold rolled plate for the slide so had to remove 25mm from one edge. The metal is pitted but I'm hoping with a smooth up on some emery the pits will end up being oil holders.
The filed edge was reasonable till I blued it which showed up a nice hollow so it had to be scraped flat.
Eventually it became as flat as the other original milled side and of equal width across.
So now I scraped the cast slide flat as well.
I'm hoping this is sufficient flat surface as it runs the full length and will wear in evenly in use.
The pads were milled flat some time ago so I didnt have to touch those.
I hope I can get back to this asap but dont know when that will be.
