Transfer case sprocket and chain
Automotive engine timing chains run up to 7000 rpm, wuth sustained duty at half that. They were good for 60k miles before better belts came along.
I hadn't considered timing chains.. I Googled it just now and there seems to be a mix of different chain technologies used. Interestingly, some of them seem to be the same type as t-case chains. In this picture you can see both used inside the same engine.
The fact that that they used the t-case-type chain from crank to intermediate shafts implies (to me) that it's good for ~2x the torque of regular (whatever regular means) timing chain. Maybe not 2x more, but "some amount" more. Then again, it's driving step-down gearing, so... I'm kinda puzzled as to why they used two different chains, and which one is better.
How much torque does it take to spin a camshaft? Timing chains are obviously good for high speed, but what about torque? I have no idea.
Look into chains from the 80s/90s/00 Ford and GM front wheel drive units. AX4S/N, AXOD, 4T60/65. Or the monster Cadillac 4T80. They handle full engine torque at engine rpm. GMs ran three chain ratios, 33/37, 35/35, and 37/33. and three diff ratios. Ford used a whole bunch of chain ratios with two diffs.
New Process Gear was owned by Chrysler. They sold transfer cases to GM until GM acquired/started up New Venture Gear. Borg Warner is a conglomerate corporation that buys other companies. It's hard to tell who owns what, but one thing is for sure, those chains are strong. Take that 400 lb-ft and multiply by the 1st gear ratio and the low range ratio- that's tons of torque.
And THEN pop the clutch!
As an example, what is currently residing on my bench, a 35/35 from an '06 Impala 3.5L. Though the 5.3L police cruisers use the same parts.
