- Jan 31, 2016
- 12,565
If they don't make or sell, they shouldn't have an issue with sending you a PDF drawing: you just have to do some cajoling to get to the right person.It is a 21" Recycler II Super Pro, and like I said Toro no longer makes or sales the parts.
Brake linings are typically bonded to metal using high temperature phenolic-based adhesives that are heat cured. Somewhere on the forums (I think this one or HMEM) in the last 6 months or so there was a thread on brake/clutch bonding cement.Mine is the vintage before the one Dave posted, and it does look a little different. That part is not available either.
eBay might be a good place to look. When I talked to Toro company they said maybe a dealer might have one in there stock. The brake pad it's self is not that big and wouldn't be hard at all to replace. I'm not even sure that it is glued, it probably is I just don't see it.
True; even if you don’t find the one you want, you can reach out to the Sellers and see if they have one that isn’t listed.you'd be surprised how many NOS parts are available on ebay.
