Here is some other options for boring larger holes. They were part of the kit that came with a Wohlhaupter boring head. Several different ways to assemble it. There may be more I did not think of.
Very large hole, a stack of bushings can be moved from right to left side as a coarse adjustment on diameter. There was a nut on the left side of the horizontal shaft IIRC.
smaller very deep hole,
lots of holders, bushings etc,
I know it was fairly old because the boring bars mostly used HSS bits and the internal grease had hardened to the consistency of concrete.
