Thanks for all of the compliments, It does look good if you are far enough away. With me being a perfectionist with no skills I do see every little flaw and chastise myself every time I see them.
The frame looks to be good wherever I can see it. I am also scraping and coating the frame everywhere I can get to. As soon as all the painting is done the truck will just about be getting dipped into Fluid Film. I already bought a 5 gallon kit with all the application guns for getting into the nooks and crannies.
Before I started this repair I did a lot of searching for a rust free box from outside of the rust belt. Everything I found was either crashed or already had cancer because they took off a good box and just laid it on the ground.
I did get some more done yesterday. I finally gritted my teeth and popped out the tail light.
This is what first greeted me as I removed the light.
These next two are after a first pass with the needle scaler to knock off the loos chunks. Lots of holes with nothing left.
I will have to cut a lot of that out and fab up some new parts to weld in. As you can see there are holes designed into the OEM parts that you can see straight thru to the contact patch of the rear tire, This means that all of the road salt, gravel and rocks have a direct path to the tail light, and then there are folds in the metal to make sure none of that road stuff can fall out once in there. There is an engineer somewhere that needs to be hung.......
