If Al welding is in your plans you NEED a HW20 water cooled torch. Once you use one you will never want to use an air cooled torch again, for anything.
I hear ya - and I agree!
After binge-watching YT on all things TIG torch related on YT, and taking the good advice and explanations from
@General Zod, I now think the best choice that matches my needs is a 20-series water cooled, even if I have to save up for it! The excellent pictures from
@General Zod are also much appreciated.
To some extent, I am "future-proofing". The 20-series can handle a very wide range, and is small and handy. Lay on top of that things like "flexible", etc, and we end up looking at the CK range. The China imports come much cheaper - but likely less flexible in the cables/hoses.
One thing to keep in mind is that the presence of water cooling in WP-20 kit has meant that the build quality and design around some brands got scaled to heavily depend on it. The amount of conductor wire gets reduced to something smaller than could reasonably handle (say) 200A without the water. The size of the torch, and the internal constructions also have to have guaranteed water
Coolant failure!
To have the cooling pump fail, or forget to turn it on, will scorch everything immediately! You need closed cycle pure distilled water, likely with corrosion inhibitors, or one of those non-aqueous coolant fluids, and a flow sensor with interlock to stop the TIG if anything to do with coolant integrity is compromised. If you are adding water-cooled kit, expect that it needs with it's own control kit box, and this extra is non-optional!
Of course, this would be my initial purchase, hence all this research and discussion, for which I have to thank you all very much.
@Janderso and
@DavidR8 will have purchased TIG kit already, and may be up to their ears in cables and hoses. Very clearly, in everything I have found, folk who have invested in 20-series water cooled kit have not regretted it. For some, it has made the difference to have TIG become their favourite weld choice method.
Here is a very useful video, with lots of actual welding, illustrating how all the torch sizes and types behave.
