- May 27, 2016
- 3,479
My welder is a 200A MIG, with the option for Lift-TIG, and was not supplied with the TIG torch, so I have to purchase that separately to get a setup that works. Please allow that I don't yet know anything about TIG other than the working principle, so I am fumbling around a bit.
I have established that for TIG, the gas and the power do not come out the same socket on (my) welder, as like for MIG.
The end of the cable to the torch has to end up with two tails, one for gas, the other for the current - or have some adapter, or Y-Junction arrangement.
I use here some example images from eBay, for illustration..
Going for 200A may not be entirely necessary, unless one day I get into TIG on aluminium, but it seems sensible to get one that matches the capability of the welder. Also, If I went for 4m (about 12ft), it would mean I need not drag cylinders around.
The Polish manual says the type needed is "TIG 17V". I assume this means "WP-17V, but I see some candidates labeled WP-17FV. I have guessed the "V" means there is a little gas valve tap knob on the torch handle. I don't know what the "F" means.
Simple separates
The first picture shows what amounts to two separate pipes put up one rubbery overjacket. The electrical connector looks the right style for the welder. only 10ft long, it has the valve, OK for 200A, and the gas connection is 3/8" BSP. This one costs £55 (£76.32)
Denim?
Then you get another style, This one also has the separate pipe and electrics, and the sheath cover looks as if made from charity blue jeans denim. This one comes with a caution about Jasic new version fittings, but here I note there is an "extra" connection. Is that for ON/OFF control or something?
Superflex??
The next one is "CK" brand, and is much more expensive. It will require some kind of extra adapter to get the connection and the gas going up it. This red thing at least does not sport feature denim. Cost is £79 ($109.18).
I have to assume that this kind has power and gas available all in one socket receptacle on the welder, though might be usable with some kind of adapter.
An adapter!
I had thought that this Parweld adapter was just the thing. There is what looks like a place to put gas up, and I can see the electrical connection. Then I see one mentions water cooling. Another does not mention water, and has a strange push-on connection though in either case, I still have no idea how it gets up to the torch. Is that screw thread "standard"?
The "extra" cable.
We come to a "Parweld" brand setup. This may be all I need, but I see the extra cable in there .This one is less costly, £40 ($55.28)
The designation is WP17-12-2SW-TELF, which may imply the grey cable perhaps for a handle-mounted ON/OF switch.
Whatever it is, it does not seem to have a valve knob.
So far, I am mostly striking out. These choices leave the questions..
1. Is the super flexible a good thing? Sure, but how good does it need to be for the price?
2. So far, I have not seen a setup that would simply connect up to in a working arrangement. What should I be aiming for?
3. What does "F" mean in WP-17FV ?
4. All the TIG torches I see look much the same, and are basically simple things. What features are worth taking the price beyond $120 or so?
I have not even started on all the other consumables. I see sets of quartz cups, and little pink cups, and "shorter" looking collet thingys, and I am thinking .. Hmm, do ceramic cups things actually "wear out"? At least I know tungsten is tungsten, but I am sure there will be types with additives.
This stuff may seem obvious to many, but I don't want to have to buy everything in the shop before I come up with the subset that works.
Simple separates
Denim?
Superflex??
An adapter!
The "extra" cable.
