- Oct 11, 2019
- 139
thank you for the detailed depth of cut ! that helps alot ! I think I have been cutting way too much and tearing up the thread !
well the idler gears on this lathe are twins on a shifting lever for forward and reverse, so you might call them the forward/reverse tumbler set
but when it is in reverse ( cutting toward the chuck) it is the 2nd gear from the spindle gear....(counting the spindle gear as ONE).when it is in Forward, the gear just spins with the other one and serves no purpose (other than to make some noise ! )
the Bad gear drives the other idler gear and then that goes into the gear reduction chain for the lead screw , it is an ingenious setup I must admit !
...if it doesn't matter about the gear size I can simply replace the gear that is bad with a 36 tooth instead of the 34 tooth !
and that is a real good gear hardly any wear on it at all . .... all I would have to do Is mill or file a elongated hole in the bracket that swaps the 2 gears in and out.....
I even have the bracket they came on but it will not fit this lathe .
if you're sure it won't matter my problems are cured ! I'll just put in the 36 tooth gear !
Bob......
Bob......
