D
I don't see it in my manual,some pages nissing and you can't find this lathe model on the Internet.
Suzuki, if you provide us with the exact thread spec of your lead screw, then the thread dial gear from any lathe with the same lead screw should work. Maybe we could provide you with the part number and source for a gear only and you could make the other parts to use that gear on your lathe. Unfortunately my lead screw is inchy or I would provide you with that information.
And as RJ mentioned above in all likelihood it would be rather simple to fit a whole thread dial from another metric lathe with the same lead screw.
