- Jan 6, 2017
- 1,234
The accelerometers (for input shaping) are inexpensive. The process collects some impressive data.
Also Nero recommends don't use stealth-chop mode, it is more prone to step loss. Use spread-cycle instead. Mentioning just in case.
Ok, that's good info to know.
Klippers setup info says:
"It is recommended to always use "spreadCycle" mode (by not specifying stealthchop_threshold) or to always use "stealthChop" mode (by setting stealthchop_threshold to 999999)."
I looked at my config file, (obtained from the Voron resources page), and currently my steppers are set "stealthchop_threshold=0"
I'm not sure what "stealthchop_threshold=0" means, since the Klipper documentation doesn't indicate that as one of the options. Or, perhaps they consider stealthchop_threshold=0 to be "not specifying a stealthchop threshold". That seems inconsistent though, since z steppper 0 certainly counts as a stepper motor, I have a fan plugged into fan header zero, a heater plugged into heater header zero, etc.
When I get home from work this evening, I'll change that value by deleting the "stealthchop_threshold=0" line, and see what happens.
