I've been wanting one since 2019, finally did it. It will be handy to have a selection of filaments "ready to go". It can also be used to feed a multi-material unit.Damn...!
I want one of those. Whether I need it or not.
Found a problem with the belt routing. Was wondering why the Trident's CoreXY motion friction was higher than the Railcore. Dismissed it as the LDO Voron motors are taller which generally means more detent torque, but while the printer was upside down and turned around for electronics work noticed part of the belt path was wrong and was significantly rubbing on the plastic. It pays to investigate these questions. Much better now, and should have cut the belts a bit shorter.
Have the DIN rails and the electronics mounted, getting ready to trim and mount the cable ducting and drag chains. Enjoying the slow build pace.
Printed a few fun little cali dragons on the Prusa, each with different filaments, good samples.
I think I know exactly what your belt problem was. I took me an hour or two to realize it when I did it.
Let me guess, in the back, where the belt loops around the corner pulley, you missed that tiny space it has to be fished through, and had it looped around part of the motor/pulley housing too. I had to use little hex wrenches as pokers, to reach in and push the belt in the directions I wanted it to go.
Some Klipper folks like Super Slicer which is a variant of Prusa Slicer but with more knobs. It is a bit behind Prusa Slicer in features, most development is on Prusa Slicer so it gets features first.
