For want of a shoe. Or what I've been doing for the last three weeks.
Needed 4 chunks of aluminium for the altitude bearings for the bino.
Guess I had better cast some.
Hmm, floods and rain so better not.
so I knocked these out for the secondary mirror adjusters.
Just have to silver solder the brass nut to the brass plate, its a larger version of what I made for the tertiary holders. BUT, my gas torch wouldnt quite get hot enough for a good joint so cant finish them off, Gaaaa.
Need a bit of brass for the remaining adjustment screws, none here, I know, cast some, oh, I cant its still raining, bugger, getting totally fed up with it so a change of tack was called for.
I had a go at turning a crankshaft, I dont have a use for it (yet) it was just for kicks to see if I could.
Got this far then Whoops! crashed the tool onto the chuck and snapped the belt and the parting tool. They are now on order so what can I do now?
As its still bloody raining I still cant cast anything but I suddenly had a light bulb moment, maybe I can machine down these horrible failed castings for two of the bearing blocks.
I started facing off the bottom of the bowel as the other side allowed (sort of) clamping.
The centre is only just there to help prevent it from moving towards the tailstock.
Then I thought why not cut the ends off with the table saw
Now I can use the rear face of the jaws or chuck to get parallel faces then square up for the other two sides then the ends.
Many many hours later and half a ton of swarf
these materialised.
The arrowed corner will be rounded eventually which will remove that unsightly bit then I may powder coat or polish depending upon how I feel.
From what I thought was a totally buggered up melt came the best cast aluminium I have ever poured, not an inclusion to be found. Just goes to show.
Oh for a mill or shaper, perchance to dream, the lathe certainly got a real flogging getting these down to size.
Ahh, the rain has stopped, the water damage has been repaired and the land is drying out.
Ta Da, casting time.
Out with the muller and prep the sand.
Not a chance, the motor has failed.
I have a 1/4 horse I can "borrow" from the mulcher so I've cut the old brackets out ready to re build.
A major problem is the motor is rated at 2850 rpm. Thats a lot of speed dropping to get down to 30 rpm.
I can make some new pulleys and whack a jack shaft in, hang on, I need the muller for the sand so I can cast the pulleys.
Guess I had better spring for a new slower motor, found a 1/3 hp 900rpm for $140AU all up so I think thats the way to go.
They say in never rains but it pours, weve certainly had that in spades of late.
Now how do I get this purchase pass the financial controller???
