- Nov 16, 2012
- 5,596
Ok, here are two basic HSS bits that I use frequently. These are all right cutters but, I have them in left side too. The first has a slightly rounded point. These are not good for cutting up against a tight shoulder but, they give a nice smooth finish in most cases. These are not fancy grinds and they are easy to make.
In all these test cuts, we're working on A36 Hot roll. The outer hard skin and scale was cut off with a carbide bit. Always use a sacrificial bit or junky piece of carbide to cut that outer scale off as it will eat-up a fresh piece of HSS. Since we're using A36, you will always get a dull gray finish. It's not really possible to get that mirror glossy look with A36 -so don't even try.
The first thing to do is measure the diameter so you can calculate RPMs.
RPMs = 4 x SFM / Diameter. SFM for A36 is about 125 and the Diameter is 2". 4 x 125 / 2 = 250.
I'm leaving the RPMs at 250 and am taking cuts of 0.008".
[EDIT: BTW, I'm adjusting the overhead lighting so that every line and imperfection shows up. This is to help demonstrate what the finish looks like].
With IPR (Inches Per Revolution) at 0.004, it's a very smooth matte finish. If you wipe it with a towel, it will not get snagged or leave lint behind. This is a finished piece of metal that needs no touching up. You could polish it with emery cloth if you wanted too.
With IPR at 0.006 it's still a smooth finish but, will snag a towel lightly but not leave a lot of lint behind.
With IPR at 0.012", still smooth to the touch but, will snag a towel and leave lint stuck in the finish.
Now comes the spear-point. I use these to get right up against a shoulder and make a clean edge.
Same RPMs (250) with IPR at 0.008". Keep in mind, all DoCs are 0.008" and that not enough to significantly change the diameter so, I'm leaving the RPMs at 250. Anyhow, at IPR 0.008, to the touch, this is a very noticeable ridged finish that will snag a cloth.
IPR at 0.004". This is much smoother and refined; still snags a cloth but not as badly.
There's more to discuss about what to use, when, where and why. All kinds of factors also come into play if you're working with low, medium or high carbon metal but there's a similar theme across the board when using these two common HSS cutting bits. For now, I just wanted to get some photos up so you can see that once RPM is set properly, feed-rate and bit configuration are what control surface finish.
Ray
Ray
