- Dec 24, 2020
- 1,211
The scale on the taper attachment is an indicator not a measurement.
Just finished cutting a Jacobs taper on the Hardinge, the indicator was close.
I use a test bar between centres, with a dial indicator on the tool post and a dial indicator on the bed or the DRO
In your case zero both indicators, move the carriage 1.15 inches and the tool post should move .030, half the taper.
Adjust the taper attachment until you get that.
Make certain the indicators are parallel to the movement or you'll get sine errors large enough to affect the measurements.
Greg
Not to argue, but why would they list the lines on the taper as inches per foot and degrees if they aren't supposed to be a measurement to get you close?
I don't expect them to be really accurate, but to set it at 1.5* and get 1.1* seems a bit much...that's off by 30% or so.
As I said in the first post, I can make the part using indicators to set the taper, I'm just trying to figure out why the scale is so far off.
