I consider myself somewhat computer savvy and of average intelligence but I've had no luck with Mach 3 motor calibration. . This is my procedure and dilemma. My X and Y axis drives are set for 1000 micro steps, have 5 pitch ball screws and are direct drive. Went to motor tuning in the config menu and input 5000 in the Steps Per box and saved the axis setting. I set up a 123 block square to the table and zeroed my DTI to the 123 block after removing backlash. Went to the Settings tab and clicked on Set Steps Per Unit, selected Axis Section and clicked on X. Input 3 in the distance to move dialogue box and clicked OK. The table moved about 3". Using another 123 block I slipped it in between the 123 block clamped to the table and my DTI. My DTI is .030" travel and evidently the table moved less than 3" because I maxed out the DTI travel. My guess was that the table moved about 2.970" so I entered that in the dialogue box. I accepted the number in the Steps per Unit box. My logic is I could run this exercise again and get closer with each successive run. Not so. Each time I ran it I am getting further away from my 3" calibration mark.
I know there are literally thousands, if not tens of thousands, of copies of Mach 3 in use so I can't blame the software. What am I doing wrong? If you need additional information I'll gladly provide it. This can't be as hard as I'm making it.
Thanks for your help.
Tom S
Tom S
