That is strange, I would love to look at the output of the wall wart with a scope and see what it looks like.
I'm stumped too. Maybe the new USB hub power supply will be the cure.
Everything seems to be working OK now. The limit switches were driving me up the wall so I checked all my wire connections and they were good, or so I thought. Had continuity from the limit switches thru to the two wires that connect to the BoB. So rather than fight it I wired each switch individually to the BoB and now I can reset. Evidently the problem was in my wiring the switches in series.
Now that all these bugs have been worked out I was able to set my limits and run G-code. And wouldn't you know it I was about five minutes into running G-code and my laptop power supply died. Jeez will it ever end? Luckily I had a spare power supply so it's not slowing me down.
Next steps are cleaning up the wiring, building a riser for my monitor, and making an enclosure. I'm not using flood coolant but want to contain the chips.
Tom S
Sounds like you need to set the hotkeys.
No, the hot keys are set under Config, System Hotkeys in the main menu bar.
Got it. I'll try this in the morning.
Thanks
