I cant rcall but is there anything in the uc100 config related to home limits?
I reread the UC100 installation manual and did not find any reference to configuring limit or homing switches. I did find that the I/O monitoring screen has a "home" indicator light. I'll check to see if it lights up when I home. If it doesn't then it could be a UC100 problem.
Tom S
The homing light on the UC100 screen lights up when the switch is tripped while homing. Wasn't able to make any more progress today because the UC100 errors are back. Jeez, will it ever end!
If I recall you are running the UC100 through a USB hub? If so try taking the UC100 out of the hub and directly to a USB port.
The mill worked flawlessly except the X and Y motors got very hot. So hot that you couldn't keep your hands on them longer than an instant. I think it may be a driver dip switch setting but will need to do more searching and reading before reaching a conclusion.
Check the idle current settings, maybe back down the operating current a bit and see what happens. Sounds like the motors are being driven over current.
Test part looks good. Are you running any coolant?
Jay
