Didn't realize that you were trying to fasten to a lathe. Just use some flat bar that fits into the wider (bottom) slot. Based on the setup, I wouldn't worry about the smaller slot. It would be more important if you were inserting a bolt that had to deal with the blind hole against the bottom of the slot, but if you are going to extend past the edges then this would not be an issue.
