- Jun 12, 2014
- 4,996
Easy alternative is to put the lock on the other side, otherwise just make a stand off for the glass scale. I find it more convenient on the headstock side and no fumbling for a wrench or key. One can set the cross slide gibs tension a bit higher and not use a lock, but may cause a bit more wear. If you are trying to hit diameter work to 0.001" or lower, a cross slide lock helps to prevent any creeping of the cross slide. Would not mount a scale on the headstock side.
ERL-1340 Cross Slide Lock for DRO Equipped Lathes
Often when doing tight tolerance work one needs to lock the cross slide to get consistent diameters along the length of the cut. My ERL-1340 was fairly tight when new, but over time I did noticed slight shifts in the cross slide position from my original setting. I am using glass scales, and I...
www.hobby-machinist.com
