- Aug 20, 2024
- 21
I have an 80's vintage belt drive Grizzly 12x24 that I recently did a 3 phase conversion on. I was having some issues with torque loss, the machine was way too easy to stall, a .020" DOC in mild steel would slow it to a crawl, any more than that would bring it to a complete stop. I did some digging and finally decided to pretty much start over with the VFD programming. VFD is a 2 HP Teco-Westinghouse L510, single phase 240 volts in, 3 phase 240 volts out, feeding a Leeson 1.5 HP 3 phase IEC motor. I was initially running it in sensorless vector (SLV) mode, but decided to start over in voltage/frequency (V/F) mode, mostly to see if it made any significant difference. I ended up doing a factory reset on the VFD, just switching back to V/F mode left behind some settings that I couldn't seem to unset.
So I got it reconfigured and all seemed fine, although my surface finish kind of sucked. I was running in lowest regular (not back gear) range, supposed to be 320 RPM at base frequency. Decided my tooling was part of the finish issue, so upped the speed to the next range (490 RPM), and switched to a carbide tool. This allowed me to get the DOC I was after, ~.050", but finish was still pretty lousy, even with a very slow feed and light DOC, so I decided to speed it up again. And this is where it got weird. I'd been monitoring output current as I went, the VFD is rated for up to 7.5 amps output, and up to this point, it hadn't gone up to 3 amps. But as soon as I shifted into the next speed range (690 RPM), the current spiked to over 9 amps running no load other than the chuck and drive train . And to make a long story short, switching to the high range motor pulley was no better, even though the speed was lower. Increasing the frequency to the motor helped, I have it limited to 90 Hz. and once I got over about 75 Hz., the current went back below 7.5 amps.
So I guess I have a couple of questions. First, is this normal, so nothing to worry about? And second, what do I need to change to fix it if it's not? I had no current issues running in SLV mode, but I also had no cutting torque. And surface finish sucks no matter how it's running, although that could be totally unrelated, and just a factor of the material I'm cutting (4130). I did use it before on both aluminum and an iron pipe fitting I needed to modify, finish on both of those was pretty good, but not great. Any suggestions or insights would be much appreciated, thanks.
Dave
Dave
