I'll give that a try tomorrow. ThanksHow did u measure this? From the cross slide is meaningless as it just follows the wear off the ways. Measure from the tailstock to the side of the v way will be better as the ways under the tail stock are usually less worn
Yes I know the Atlas 10" isn't. The new/old SB looks to be original.The mounting plate for the tail stock isn't original (if you didn't already know).
Here's what I did on my Clausing so I don't forget. Originally wrote on the lathe with a Sharpie then printed labels with a Brother label maker. Smarter person would have cleaned the Sharpie off first . . .Oh dang! That really makes sense!!! Glad you been watching over me all this time. Now I have one less worry about some more money to be spent on worn out parts. Thanks
I'm quite aways from getting the counter shaft-assembly and motor installed. Once installed I'm have to get a flat belt measurement and order it. Still have to strip, clean and paint the various parts. I also wrapped the horizontal traverse gear shaft with shim stock and tightened it up quite a bit.
What I like about the flat belts is that I can pull the joining pin out instead of removing the counter-balance shaft to install/remove the belt.For the flat belt I use a 445K6 serpentine automotive belt works great! <$7 on ebay
445= 44.5" and K6 = 6 ribs approx 7/8" wide
How's the fit of your new tailstock to the bed ways?
