- May 26, 2015
- 875
The "bed teeth" is called a "rack".
Are you sure that the gear is that worn? If things don't properly line up, you'll never get the lead screw in place.
Yup! Plus a little shaft or apron casting wear.
UPDATE 1/30/20: Going to wrap the shaft, where it goes thru casting, with shim stock to take a little of the play. Could buy new gear with shaft for $39 but I see how this works out.
