Since you have a mill and a welder... maybe get some nickel 99 rods....and do a few light passes ... filling in the missing piece. Make sure to preheat the compound to about 250 degrees F. After each pass...let it cool about 5 minutes. I’d go on the low side of the recommended amperage so that it kind of lays down better and fills in more than heavy penetration which I tend to get when I set my welder to the higher amp settings.
once you’ve fill it where you want it, dunk it in a bucket of sand...dry sand...and let it cool slowly. Sand will work....vermiculite insulation is even better. But the main thing is to let it cool slowly so you don’t get cracks.
Then mill off excess. i was thinking about welding steel on top but cast iron and steel welded together just don’t mix well. Tends to cause cracks as it cools.
Plus, if you add a support piece on top of it.... make sure the added height doesn’t screw up your tooling of your quick change tooling.
Sometimes it’s better to not overthink this stuff in my opinion. Just go the easy route. Weld some nickel 99 and mill off the excess.
I think you could get by with a 13mm or 1/2” end mill. Just do multiple passes and go easy on the cuts. Yeah, a fly cutter would be nice, but I don’t think you absolutely need that. Nickel 99 rod mills fairly easy.
