- Oct 19, 2020
- 164
Forum,
I am working on improving the cross slide feed screw threads on my 1975ish 10K.
This is the dial side of my cross slide.
The dial is held on by this split nut.
The threads on the feed screw have been damaged to the point that the nut does not thread on the whole way. Looks like Bubba didn't have a split screw driver blade so he wacked the general area with a chisel. So before I proceeded, I made a proper screw driver.
You can see the very end of the damaged screw here.
My plan is to carefully run a die onto the injured threads. Does anyone know what size die I should use? By screwing a tap into the nut, I came up with 7/32-24. Does anyone agree? Turns out that this is not a very popular die size and has been a little tricky to get my hands on as it has been backordered. So confirmation that 7/32-24 is in fact the correct die to use would be appreciated. Thanks much.
