Carriage lifting/tool diving update
While using a boring bar the tool diving/carriage lifting problem happened again. The good news is that I was boring threads out of the stock so the dip/lift was cyclic and gave me some time to troubleshoot. The motion was the greatest at the right rear corner of the carriage. After locating the fasteners that hold the “strip” (that’s the technical term for it according to the manual) on among the caked on oil and chips I pulled in off and gave all of the parts a good cleaning.
Sorry; no photos since my hands were way too grungy to touch a camera or phone. I’ll try to give a good description in case anyone else needs to attempt this. As nasty as it was with foul smelling old oil/coolant and thick caked on chips in places that seemed inaccessible to chips, it didn’t take too long to clean it up. The gibs had obvious wear. I didn’t measure it but would guess it was around .010” judging by the unworn ridge.
The strip holds two flat gibs, each about 3” long and each gib has two adjusting screws and locknuts. The gibs are located by drilled dimples for the set screws. With the gibs sitting in place on the strip they got a good dose of way oil and the strip was bolted back onto the carriage. I moved the carriage well away from the chuck end of the bed to get it to an area w minimal wear, tightened the gib set screws and snugged the lock nuts.
Moving the carriage took just a little bit more force on the carriage hand wheel than before at the unworn right end of the bed and as it moved left the slight drag disappeared. Another pass or two with the boring bar revealed that almost all of the tool diving and carriage lifting was gone. Before the adjustment there was a strong pulsing in the cross slide hand wheel. After, I could barely feel it. By placing a finger on the juncture of the bew and the carriage I could feel a very tiny bit of motion but nothing like before the adjustment. I’m calling it a 90%-95% improvement. I think the only way to make it perfect is to have the bed reground. It’s very workable as is now.
