- Apr 14, 2014
- 3,546
Over the years I've worked primarily in imperial measurements including fasteners. However as of late I've run into a number of machines that require metric fasteners. Up until now I've run to the local hardware store "as needed" when something metric has been required. The last go around with my Baileigh cold saw was a bit of a nightmare. I must have made half a dozen runs to different local hardware sizes stores to find they either didn't carry the sizes I was looking for or were "temporarily" out of them. When I did finally find ones the I needed the prices were in my estimation outrageous. If I added in the cost of time and gas, I think bolt would be in the $5.00 range.
To save time and hopefully money in the future I think it's time to start stocking the more popular sizes of metric nuts and bolts. I'm thinking of a couple assortments of hex head bolts to begin with. One assortment of 2mm to 6mm in various lengths and thread pitches, and a second with 6mm to 12mm again with various lengths and pitches.
I'm considering something along these lines where the assortment comes in a container with each size and pitch identified. I have no idea whether the ones in the links are of sufficient quality. I would like self-contained assortments to keep them separate from the imperial sizes
575 Piece Metric Bolt Kit Assortment M6-M12 Zinc Class 10.9 / Hardened Grade | eBay
DIN 931 / DIN 933 Hex Cap Screws Zinc Clear. -(60) M6-1.0. -(16) M8-1.25x20 -(5) M12-1.75x30. -(25) M6-1.0x20 -(10) M10-1.5x20. -(20) M6-1.0x25 -(10) M10-1.5x25. -(15) M6-1.0x30 -(8) M10-1.5x30. -(20) M8-1.25x16 -(5) M12-1.75x25.
www.ebay.com
420pcs M2 M3 Stainless Steel Hex Socket Head Cap Screws Nuts Assortment Kit With 733180273420 | eBay
High Quality Stainless Steel Hex Socket Head Cap Screws Nuts Kit. 30pcs M2 X 20 30pcs M2 X 16 30pcs M2 X 12 30pcs M2 X 8 30pcs M2 X 6 60pcs M2 Nuts 30pcs M3 X 20 30pcs M3 X 16 30pcs M3 X 12 30pcs M3 X 8 30pcs M3 X 6 60pcs M3 Nuts.
www.ebay.com
