Thanks @WobblyHand ,Many cheapo LED's have low Peak Inverse Voltage (PIV) rating - far under 110V. What I am saying is many LEDs (5050, 3030 white) will fail within 1/60 of a second, since their PIV was exceeded ( 3030 PIV is 5V), unless it was designed to be connected to line voltage. LED Christmas lights are a good choice since they are made for line voltage.
You are right about the reverse voltage rating. I was not thinking of this when I suggested the LED and resistor. One would need to do a resistor divider etc first. Another approach is to put several LED in series and so the voltage is divided between them so as to prevent reaching the reverse voltage limit, which is what I think the LED Christmas lights do. (This is what is commonly done for very high voltage power supply rectifiers, a number of 50 volt diodes in series) I don't think the LEDs in the Christmas lights are special in this regard. However, in the modern LED Christmas lights I think there is a shorting resistor wired in parallel with the LED so that when a diode burns out the whole string of lights do not stop working, but I am not positive about this. This is what is done with the strings of small incandescent bulbs any more. For this reason the strings come with a fixed number of bulbs of a given voltage drop. For example in one string I purchased each bulb is designed to drop about 2.5volts so there was about 120/2.5 = ~ 50 bulbs. They conduct about 170MA so the resistance is 2.5/.170 = ~15 Ohms. So each bulb is using about 0.42 watt (2.5*.170). These voltages and currents are RMS values.
There are other voltage bulbs available.
The fluorescent bulb rectifies the line and produces a spike of light on each half cycle. This is why it puts out 7200 pulses per minute and not 3600.
@yota Love the vintage Jagabi mechanical indicator! Do you know how they work ... inside mechanics? Is there a patent number on the back of the indicator that we could use to look it up? If I understand the instructions, it appears that it some hows counts vibrations for a fixed period of time?
Dave L.
