Many cheapo LED's have low Peak Inverse Voltage (PIV) rating - far under 110V. What I am saying is many LEDs (5050, 3030 white) will fail within 1/60 of a second, since their PIV was exceeded ( 3030 PIV is 5V), unless it was designed to be connected to line voltage. LED Christmas lights are a good choice since they are made for line voltage.60 Hz line is pretty accurate. Just hook up a resistor in series with an LED to the 110 volt mains and it will blink at 60 times a second => 60*60sec/min = 3600 RPM. Most small LEDs will easily carry 5-10 milliamp of current. So 110Volt line / 5ma = 22,000 Ohm resistor.
In fact, if you happen to have a string of LED Xmas lights that plug directly in to the 110 line (no power supply) they probably blink at this rate. The eye cannot see things changing this fast so you do not notice the blinking. I just checked, you can get a string of lights from Lowes for ~$10.
Jake is spot on re the slip & to stay with simple: no load = no slip = theoretical speed based on motor & power properties, and it's pretty easy to calculate.
And 1800rpm is exactly what's expected out of an idealized 4 pole AC induction motor on 60Hz mains.
For this purpose, that's approaching the reinvention of a fluorescent light bulb. (Unless you didn't have said bulb, of course)60 Hz line is pretty accurate. Just hook up a resistor in series with an LED to the 110 volt mains and it will blink at 60 times a second => 60*60sec/min = 3600 RPM.
Exactly. I went back & bolded "idealized" & added the conclusion I accidentally left out:Idealized is the key word there. An idling electric motor is not idealized. You never see 1800 RPMs. And you never see the data plate RPMs until it's loaded "some". At a larger load, it's well under.
