- Sep 18, 2016
- 15
Your first photo looks like a tachometer that operates like a car's speedometer - indicating revolution rate on the dial. The operating principle (at least for a speedo) is that the input shaft turns a magnetized disk. A neighboring disk of copper is connected to the needle or dial, which is spring loaded to return to zero. As the magnet turns, it induces eddy currents in the copper, "dragging" it along. The force is proportional to the rotation rate. I'm not sure how the 200, 2000, 20000 scale is selected - possibly gear ratios between the input shaft and the magnetized disk.
Thanks for the explanation. I saw another of these that was branded by Lucas whilst looking it up online so not sure who is rebranded who.
The second item is a turns counter. To measure rate, you touch the end of the shaft to the shaft you want to measure, for a timed interval, then read the number of turns on the dial. The counter is (originally) supplied with a variety of concave and convex rubber tips, for coupling to various sizes and types of shafts. I've used one, but that was back in the late '50s.
This makes more sense, I was wondering how it could count rate with a limited number Doh.
