I have Helios, Starrett, Mitutoyo and Etalon analog calipers and a Mitutoyo digital caliper. All work well but for analog, the Etalon is by far the best of the bunch. Smooth and very accurate and Long Island Indicator considers it the best of the breed.
The Mitutoyo 500-752-20 digital is incredibly accurate, smooth, has large digits that I can read with my old eyes and is coolant-proof. I'm on my second year with the same battery; I'm sure the auto-shut off helps.
To assess accuracy, I checked my Etalon and Mitutoyo digital against my Mitutoyo grade 0 Cerastone gauge block set and both read dead on. This gauge block set is in the range of 0-4 microns, which is way beyond what a caliper should be able to register, but both read dead on for every single block in the set. I also wrung the 1" and 3" blocks and both still read dead on.
Tesa, Etalon and Brown & Sharpe calipers are made in the same factory but the Etalon has a thumb wheel, which is important to me so I can recommend it. The Mitutoyo digital I cited is the most accurate, smoothest and easiest to read caliper I own and I can also recommend it. If I could only have one, it would be the Mituotoyo digitial but mostly because I'm an old fart.
