Simple Rotary Table
excellent work, thanks.
but no thanks for sticking me with another project:laughing:
Thank you all again
I have used it several times and works fine.
Ray
This picture shows how the table brake is assembled. It pushes against the table spindle land above the worm wheel.
This is how I cut the divisions using the bed of my lathe. I messed up on the first try so I cut them off and had another go.
360 marks of different lengths was quite a job but I only made a couple of minor oops.
After a little bit of sanding than a coat of paint. (wife's finger nail polish)
This is the result.
They are not all perfect but they turned out better than I had hoped.
I don't think I will try to number them now as that never turns out very well for me and I am not sure it is needed.
The long lines are 90 degrees apart and the next shorter ones are every 5 degrees. It should be easy enough to figure out.
Thanks for the likes everyone and thanks for looking.
Ray
Great work
This is the result.
Ray
great work.
Is nail polish the recommended material for colouring the marking
Very impressive project all around Ray. I would be delighted with an outcome like that, one big att'a boy, on a job well done. Cheers, Mike
Thank you brino
The box cost me more than the table did.
Thanks all
Ray
A very impressive project, great attention to detail, and beautifully finished. I can only aspire to such quality work.
