Thanks brino
After examining the dial closer it is some of the 5 degree marks that are off by about 1/2 degree. All the 1 degree lines and the 90 degree lines look fine. It must have been that I had the brake a little too tight when I did the 5 degree lines.
I did a little more cleaning up all over and assembeled.
Marking holes for my 4" 4 jaw chuck mounting plate.
Here it is all done for now.
I may add some T slots later but most of my work will be either in the 4 jaw or through the morse taper.
It weighs just over 11 pounds and very sturdy.
When I started I was going to make a simple rotary table but as it progressed the project just kept on growing.
I have surprised myself how it turned out.
I want to thank everyone for suggestions and encouragement along the way.
Thanks for looking
I told my friend Chris that I was going to make a box to store the rotary table and the pieces that went with it and he said it will probably be some exotic thing with mitered corners.
"No" I told him just a simple wood box for storage.
Well like so many of my projects it got a little out of hand and one thing led to another.
The table sits in a recess in the bottom and I had to cut out some of the side for the table to fit.
It has felt feet on the underside so it won't get scratched.
Maybe over the top?
