- Sep 10, 2019
- 157
Hi, Can you show us your cool design with casters?Cool. My saw is on 4 larger casters so I can maneuver it in tight places
Hi, We're saw manufacturer from Taiwan,many customer suggest us to add wheel set on the machine, therefore, we would like to ask some question below:Hello,
Here are simple modifications I made to my HF bandsaw. I used a simple plastic cart and mounted the saw to it using uni-strut. The uni-strut made a strong base and allows me to use it in a vertical or horizontal position easily. The tray can be used for a coolant in the future.
Hi, Thanks for your sharing. The photos you send to us is your garage? or some where in your home? did you often to cut something in this place? or you have to move to other place for cutting?My Craigslist find, 2002 model, made in Taiwan. The saw is solid but the stand is trash so I got a stick of 1 1/4” tube and a stick of 3”x3” angle and this is the result. I will be doing several more mods before this project is finished but I felt like a good base was the place to start. A down feed, true up the drive wheels, beef up the vise, maybe a VFD and 3ph motor are also planned. I replaced the guide bearings and aligned the new blade after I got the saw and it cuts square and true so I have a good base saw to start with.
More later.
View attachment 309466View attachment 309467
Yes, the saw is in my garage and used there. It is stored pushed up against the wall and rolled out into the open floor for use. This is still a work in progress. First primer paint coat applied today, second tomorrow, then paint, etc.Hi, Thanks for your sharing. The photos you send to us is your garage? or some where in your home? did you often to cut something in this place? or you have to move to other place for cutting?
Nicolas, it seems that you're not getting much traction with answers.Hi, We're saw manufacturer from Taiwan,many customer suggest us to add wheel set on the machine, therefore, we would like to ask some question below:
1. What is the purpose for you to have this wheel?
2. Is it necessary for you? why?
3. What environment you put this machine while cutting? does it relate to the wheel? I mean if you need to cut something, will you move your saw to outdoor?
4. What will be the recommend wheel size or design by your opinion?
5. Does those wheels will be the first priority for you to make decision when you want to buy a saw? why?
6. What is your job? a home user? please share with us any relate to the wheel set, thanks
