- Jul 14, 2017
- 2,455
I would love to know what comes next before you attempt, maybe we could offer some alternative solutions. Best of luck
I appreciate any suggestion, so next i want to start on the base for the drill press, to mount the pipe then move back to the quill so the work won't be monotonous, for the base i plan to use this 100 x 60 x 8 mm pipe is extremely heavy and should not flex, i plan to put thick gussets, in the last three photos i've mock it up with papir the in the front i plan to put that aluminium pedal for emergency brake, i'll install a switch that will cut power to the motor and a motorcycle brake cylinder and a disk brake on the last pulley, now the question is where do i place the pipe, all the way back, in the middle or in front of the base pipes?
