It will move as the weld is cut so watch it.
Another way to straighten is how auto cams and cranks are done and not with a press.
You place between centers and find low spot.
Next get SMALL hammer and a chizel and get ready as this seems backwards....Ww did this in an engine shop and brain fights it....
Place low spot UP... Or high spot down whatever makes sense and take chizel and place on top of shaft in middle of weld and a few gentle taps and rotate shaft a bit to form an arc.
Your brain thinks taping towards bend will bend more but the chizel relieves stresses and that side gets wider thus shaft moves TOWARDS the chizel.
This was done on bent cams and welded cranks to straighten before grinding.
Bending by force will move a bunch when machined and bending by stress relief also moves but not as much.
It does take time and be gentle
