I stopped developing a tailstock spindle with offset taper (for correcting tailstock misalignment) after I measured significant vertical misalignment on the headstock spindle. Eric B suggested removing the wrinkle paint from the lathe base where it contacts the lathe bed. I removed the wrinkle paint; the misalignment was cut in half. Eric B then suggested mounting the lathe such that the entire length is supported on a solid piece of material.
On the two days after Thanksgiving, I experimented with my lathe mounted on the table of a Bridgeport-clone mill at work.
When I first placed the lathe on the mill table, I found that the lathe base rocked. Placing a 0.010-inch shim under the front, right mounting hole stopped the rocking.
The base did not rock when the base was placed on two 1-inch wide parallels, with the parallels located under the base mounting holes.
I decided to mill the bottom of the base flat, using the Bridgeport-clone mill and an indexable face mill. I attached the lathe bed directly to the lathe base, using long 10-32 flat-head socket screws, washers, ,and nuts. Here is a photo, taken shortly before milling:
After milling the base, I checked the flatness using a 1-meter-long straight edge (Kinex, 0.0014-inchj claimed straightness along length). The bottom of the base was higher at the middle of the length, due to deflection during milling I think. I used the straight edge, a file, and a permanent marker to flatten the bottom. I think that I got it flat to within 0.001 inch.
I reassembled the lathe, and measured the vertical misalignment of the headstock spindle using an alignment bar, tenths dial indicator, and Novaflex holder and base. Here is a photo:
The nuts on the strap clamps were finger-tight.
Here are the measured vertical misalignment values, across 2.75 inches from left to right:
- lathe mounted directly on mill table, motor NOT installed on headstock: +0.000,7 inch
- lathe mounted directly on mill table, with motor installed on headstock: +0.000,8 inch
- 1-inch wide 0.010" brass shims between lathe and mill table, under base mounting holes, no motor on headstock: +0.001,0 inch
- 1-inch wide 0.010" brass shims between lathe and mill table, under base mounting holes, with motor on headstock: +0.001,2 inch
- 6-inch wide brass shim under left side, 4-inch wide brass shim under right side, no motor on headstock: +0.000,9 inch
- 6-inch wide brass shim under left side, 4-inch wide brass shim under right side, with motor on headstock: +0.001,0 inch
I conclude that the headstock spindle does have vertical misalignment.
The misalignment was the least when the lathe was mounted directly to the mill table. This supports Eric B's recommendation to support the entire length of the lathe base with a solid material.
I was surprised by the small effect of the headstock motor. I expected greater increases in misalignment from its significant weight. The small effect is good news.
Karl
