I've had a chance to play around with the power feed I built, and for me at least, it looks like a winner. As I've stated previously, I tend to take cuts of only .010 deep, but to see what the drive could do, I made cuts up to .030 deep in mild steel and the drive didn't seem to hesitate at all. Not very scientific, but with everything cleaned up, lubricated and adjusted, it worked fine. The test cuts were made with the 200 rpm motor installed. I'm thinking about changing that motor out for one that is rated at 100 rpm for better control of feed when turning a diameter. The down side of that would be giving up how fast the feed unit can get the saddle to move out of the way when I want to get a measurement or something. At 100 rpm on the lead screw, that's still about five times faster than the Sherline unit I had. My original reason for building this thing was to get away from having to turn the feed dial by hand when I needed to move long distances. The ability to independently adjust speed and change direction is great. It's all about give and take as far as speed and torque are concerned. I may find that the 100 rpm motor is an even happier compromise. If the 100 rpm motor works out as I hope, I've got a pretty wild idea brewing that I want to work on next.
