I wanted to show you what the feed motor does but I don't have many pics of something like that. I do, however, have a pic of my live center and I used the feed motor to machine the thing. The bearing housing and tailstock arbor are 1144 Stressproof steel and the tips are O-1 tool steel, hardened and tempered. The components you see are as they come off the lathe - no polishing, sanding or anything. The only process used aside from turning is employing a graver to soften all the edges.
Everything you see here was made on the Sherline lathe with HSS tooling and most of it employed the dc feed motor. Most harder steels, like 1144 and O-1 in particular, like to be finished at high speeds but looow feeds if you want a good finish. It is difficult, at least for me, to get a consistent finish manually. So, for harder materials you want to use low speeds with moderate feeds to rough and high speeds with fine cuts at low feeds to finish and a power feed will aid in both instances.
Imagine if your speeds and feeds were tied together via a gear train; how do you run at high speeds and low feeds if you don't have the gearing to do it? My Emco Super 11 can get close to this (I have a quick change gear box and a full change gear set) but it won't produce the finish you see here, not even on its best day. Most "machinists" consider the Sherline lathe a toy but in my view, they are naive.
It is my opinion that a Sherline lathe needs a small handful of mods to be really useful - a good live center, a rear mounted parting tool, variable power feed and really good HSS turning tools. A graver and a good knurler are icing on the cake.
