Shaper Therapy
ltlvt
H-M Platinum Supporter
Aug 29, 2019
1,285
Here I am at it again sending myself to school on my little Southbend 7 inch shaper. Continuing with the toolbox dollies. But today I followed up the shaper work with some rough metrology. I'm not okay with just making a chip. I want to fully understand how the chip gets made and the end result after the chip is in the trash can.
I did do an informal map of the one piece checking the thickness of the part in 6 places. I also did a flatness check on a surface plate with Prussian bluing. My camera phone does such a lousy job of communicating surface finish I didn't take pictures of the blue. However, I did verify the flatness with blue and surface plate by taking the 6 different measurements and both revealed the same results. As you can see the middle is thinner than either side and that is not what I expected to see. Just the opposite. I took the measurements using a mechanical digital Mitutoyo mic and measured to the nearest 10th. I also used a mic stand and repeated all 6 measurements several times just in case it was lazy error. If you love shaper work and precision as much as I do stay tuned for more of "As the Shaper Shapes" I'm going to try to follow the rabbit all the way down into the hole and see if I can make a difference or is it just plain Jane shaper noise. Here are a few pics of what I measured.
The first picture just shows what the shaper can reveal below the original surface. These are just surface bruises that were revealed after the mill scale was gone.
Is it possible that the vise holding the work piece when clamping caused it to bow up by a couple thousands? Just a thought
Nuts it is highly unlikely because the Southbend vice is only a max 4" and the handle to tighten the work is only about 5". Just a good snug squeeze is what I use when on the little Shaper. I also use a light hammer to make sure it is al the way down against the parallels.
