Setting-up the PM 1236-T Lathe
Dabbler, I guess I'm always in a hurray. I've never used a lantern.
My lathe is a beauty, at least to me. I pulled it apart (except for the headstock) to clean and lube it and was amazed at how precisely everything is designed and built. Everything fits, nothing needs to be forced, and the machining is top notch. Little touches, like that carriage stop dowel pin, are everywhere. Zero backlash on the cross slide and compound feeds result in reduced chatter and prolonged component life. Precision ground and hardened spindle running in FAG bearings results in zero spindle run out with little heat generated. Hardened and ground gear train with FAG bearings make it quieter at top speed than a Compact 8 running at low speed. Rohm-built lathe chucks and live centers, Llambrich or Rohm drill chucks, etc, etc.
At the time the Super 11 was built, it was their flagship. Built to a DIN tool room standard, they used top shelf components to assemble it. Those Austrians sure know how to build a lathe!
Mikey, she sounds beautiful. You will have to send a photo sometime. By the way, I ordered a spare cross slide leadscrew and nut for my lathe and will adjust to zero backlash as you recommended. No such adjustment available for my compound though.
Mikey, I just calculated that the force of the carriage stop pin on the saddle body is almost exactly 750 lb/ sq. in. the way I have the clutch adjusted. Quite a lot, I think. I may put a plate there to spread out the force a bit.
I don't have a good shot of it right now. Here is what it looks like:
287425
Glad you bought a spare cross slide lead screw and nut. That takes the most wear because it is being constantly adjusted when we run the lathe and it sustains all the radial cutting forces when we cut. Minimizing backlash reduces the slamming of the flanks of threads for both the screw and nut, thereby prolonging their lives while also reducing chatter potential and improving finishes.
Or you can just drill and install a hardened pin. I have another one installed on the rear of the cross slide to prevent damage from the tailstock slamming into it when I'm not thinking. This was also Emco, not me.
Coolant and Guard System, cont’d
Next I will move on to what attaches to the lathe: the Repar TC-1 coolant and guard system and also the making and installing of some splash guards.
The Repar TC-1 coolant and guard system is nice because the vertical post that holds the hinged guard also acts as a conduit for the coolant.
The first thing I did was to enlarge the holes on the new bracket to accept larger M8x1.25 screws, then I disassembled the system and painted it with some of the extra touch-up paint I had mixed earlier. The original color is a safety yellow that you see in the brochure. I removed the stock PM irrigation tube then drilled and tapped the carriage to accept the new bracket.
A couple before and after shots to show you where I am head:
View attachment 286299. View attachment 286300
Pre, post enlarged holes, painting:
View attachment 286306. View attachment 286307
Drilling and tapping carriage for the new bracket. I wanted to make sur it did not interfere with the four holes to the right which are for the PM taper attachment. Take your time with this:
View attachment 286308. View attachment 286309
View attachment 286310. View attachment 286311
Now I can attach the tube and connect it to the hose. There is an incredible mix of hose fittings here that took a while to sort out. Not even the manufacturer or the distributor could tell me what they are so I ordered a pipe three ID kit from Parker and figured them out. The fittings are stainless and are from McMaster-Carr. Again, if you need part numbers let me know:
View attachment 286312. View attachment 286313
In the second photo above I want to mention that the Repar guard came with a flimsy nylon screw on the bracket to tighten down the tube. I imagine they want to protect the tube but they just do not hold the tube at the correct height and allowed the tube to rotate, so I added a 1” collar with set screws and replaced the nylon screw with an M8x1.25 socket head cap screw.
I then added the guard to the tube. The attachment point for the guard also had a flimsy nylon screw that I replaced with a stainless knob so that I can remove the guard without tools:
View attachment 286314. View attachment 286315
I then made some splash guards; one for the front and one for the back to help contain the coolant. I made them out of 14 gauge stainless. I first cut them to size, sanded them to give a matte finish. I did not want them acting like a mirror and giving me unwanted reflections. The back guard I bent to 90 degrees and attached to the Repar guard. The front splash guard attaches to the carriage. Some shots of the back splash guard:
View attachment 286318. View attachment 286319
View attachment 286317. View attachment 286320
Now for the front splash guard. Again 14 gauge stainless, sanded, then placed in a pinch roller to bend. I inserted it into the pinch roller only in one direction so that a flat area was preserved. I used this flat area to attach it to the carriage. I drilled and tapped a couple holes on the carriage to hold it in place. Again, take your time here. You might notice that the upper edge of the splash guard is outside the guard; this is so the dripping coolant fluid will fall onto the splash guard and run into the chip tray and return to the pump.
View attachment 286324. View attachment 286326
View attachment 286325. View attachment 286323
View attachment 286322. View attachment 286327
I used Hangsterfer’s CC 22 cutting oil. I decided on this after a conversation with the people at Hangsterfer’s. According to them it is a good all around cutting oil and coolant that works well with stainless, aluminum and titanium. I did not want to go with a water based coolant because of corrosion issues and apparently it can develop a bad odor. I just couldn’t see spraying my new lathe with water I would rather coat it with oil every time I use it. Would like to hear what others think about this.
View attachment 286329. View attachment 286330
I am going to post this and finish up a little later with the electrical hook-up(easy) and maybe one or two loose ends.
Does Hangsterfer’s Sell through a distributor or did you have to buy direct?
How long have you had the cutting oil in your machine before you changed it out or doesn’t it need changing out? I guess I am looking for your experience with Hangsterfer’s CC 22....
Firstgear, I have had the CC 22 for six to nine months. I don’t believe you need to change it like a water based system which was part of the appeal for me. I phoned Hangsterfer’s and talked with one of their engineers. I told him that I often work on titanium, stainless and aluminum and he recommended CC22. I have been happy with the choice and I like that I am spraying my machine with oil, instead of water, every time I use it.
I purchased it from Golden West. Here is their link:
Hope that helps
V. Adjustments
A. Aligning the Lathe
B. Checking Specs
287994
B. Aligning the Lathe- Even though I am waiting for supplies to complete this section I thought I would push forward on what will probably be the last section of this thread on setting-up the PM1236-T. I appologize up front to those with more experience than myself for the basic nature of this section but I wanted it to be useful to everyone, regardless of their lathe experience. I believe aligning the lathe correctly is one of the the most important adjustments one can make as far as getting accurate and reproducible results, so I thought I would present each step, give my results for my PM1236-T and invite discussion from everyone, including the more experienced operators; maybe it is time to tune-up the old girl?
What gives with the railroad track photo? Well, this is the image I would like you to keep in mind as you align your lathe. This is the view you would see if you were sitting on the Headstock of a well aligned lathe, legs straddling the spindle: straight, untwisted and perfectly parallel Ways that seem to extend to the horizon.
Of the several sources I consulted on aligning a lathe it was surprising to me that there was some disagreement on the order of the steps. For example, even though the PM Manual section on aligning the lathe is well written it presents aligning the Headstock and Spindle Centers before aligning the Headstock with the Ways. This approach does not make sense to me and I will tell you why in a bit. I think in the case of aligning a lathe the order of operations can make a difference in the outcome.
As far as alignment is concerned, the lathe has three parts: the Ways, the Headstock and the Tailstock. One must first untwists the Ways, then align the Headstock with the untwisted Ways, then align the Headstock with the Tailstock. Then, they are all in alignment with one another. Here are the four basic steps I will go through:
1. Leveling the Lathe and Stand
2. Untwisting the Ways
3. Aligning the Headstock with the Ways
4. Aligning the Headstock with the Tailstock
For some of the steps there are multiple ways to accomplish them. For example, for aligning the Headstock with the Ways there are cutting and non-cutting techniques and for aligning the Headstock with the Tailstock there are four ways that I was able to find. You experienced guys may know of more. I will present all that I am aware of and you can decide what suits you best.
Step 1. Leveling the Lathe and Stand- this section is probably not what you are expecting. It seems that often when I hear one say “leveling a lathe” they are really talking about Step 2, which is Untwisting the Ways. Here, I am just talking about making the lathe and stand reasonabley level so that in the next step one can use a precision machine level, or the best one you can get your hands on, to untwist the Ways. As I am sure most, if not all of you, are aware a lathe does not need to be level to cut true; one makes the lathe level so that one can use of a leveling device as a tool for untwisting the Ways(and, perhaps more importantly, so your favorite beverage does not slide off the Headstock)
In this step, all you want to accomplish is to use whatever leveling mechanism you have on your stand(bolts and pucks as is stock for the PM 1236-T) to level the lathe from left-to-right(longitudinally) and from front-to-back(transversely) so that when you place the level on the Ways or Carriage it reads in the central part of the scale.
Here is the stock PM puck and bolt system and your endpoint of the first step:
288007 288009
Use either a precision ground block with a notch to span the V-way or place the level directly on the carriage. Surprisingly, the result was exactly the same:
288010 288008
With the way I have my 1236-T set up leveling is an easy matter: I just adjust the leveling feet while I watch the spirit levels on the bottom of the baseplate to get me in the ballpark, then I place the precision level on the Ways or Carriage and fine tune with the leveling feet then lock down with the caster lock nut.
288015
288013 288014
Either way, that is all there is to the first step, now you are now ready for the next step, Untwisting the Ways.
288016
Step 2. Untwisting the Ways(AKA “Leveling”)- this obviously is not what you want to see when you are looking down the Ways from your Headstock. I put this picture in because I want to make a point that I will discuss with my next post(probably tomorrow) on untwisting the Ways.
Post #170 was deleted because a drawing and photo did not appear in the post. I thought it made the post confusing so I re-posted it with the drawing and photo in post #171. Sorry for the confusion. TK
