Brushless servoMore info! Is this a DC motor with brushes?
What if anything are you using for feed back?
Does the drive have a auto tune function?
Where is the gain set at?
Only aluminum so farhave you been cutting any ferrous metal? Any chance you have iron filings working there way into the permanent magnets?
I did the reset last night after putting it back together, will try hooking the belt up today to see if it's better. Thanks for the other tips, I'll bet it is a setting that I messed up accidentally, it's been a little too long to get a refund so I don't have anything to loose right now.I just put the 750 watt version on my drill press. So far it has run fine. I have the exact same manual and I have talked with the seller about some of the options. My guess is, you need a new controller, but you could try a factory reset of the controller and see what that gets you. There is a guy in Fl who has new boards for $50.
BEFORE you do this, make sure you know what P17 is set for. You will need to reset it. To enter programming, press P and S at the same time. Then browse up/down thru the functions.
See the first line under "Special Function" to do the reset.
Also, you might want to play with P6 and P8. I set them as low as possible. P8 set to 0 coasts to a stop and saves wear and tear.
Let me know if I can help.
Robert
Dat510 is on the right track I think. Run your screw assembly off of a drill at various rpms and see how it feels......If It ran ok to start, then something changed. Since the motor runs smooth when not hooked to anything. Could it be swarf in the pulleys, damage or swarf in the belt, bearings going bad in spindle and or motor (when side load is applied)?
